deedoo
- Nov 20, 2011
Wondering what the rear shock center coil spring rate is on a 2012 nytro xtx.
Example: spring rate (LB/IN) = ??? pounds, free length, wire diameter
Im out of adjustment to make the spring stiffer the shock is calabrated to soft and spring rate is also to soft.
