xtx installing 2.25 power claw
kodak
newfoundland,canada
just wondering if anyone has done this and did you change the gearing for low end grunt any tips problems or suggestions would be great sled is apart right now and track should be here tomorrow also if someone could tell me what suspension settings are on the xtx le and what gearing they have. Thanks
Does anyone know what should be done to xtx se when installing 2.25 power claw. remove tunnel supports or swith mounting location of suspension any help or personal experience will help
Yep.
Remove tunnel protectors, they are not there for support reasons (otherwise M8 would have them) but for protection from studs against the tunnel. Put the skid front mounting location in the bottom holes and the rear in the center holes. I assume you already have a 160 or 145 front skid shock spring put in so you should be good to go. I cannot imagine any reason you would need a gear change.
