bradb
Has anyone went from a 144 to a 152 or 155 using extensions on a XTX? Thinking of doing this and a 2" challenger track with extroverts.
linemech31
Would like to know this too.
Yamanimal
I'm no expert, but if you really want a 153 you could probably relocate the
skid further back , I think extensions to a tipped up rail is only going to raise the back of the track higher off the ground. I dont know it would improve anything. But again I am by no means an expert.
THEROOKIE
OFT racing makes a kit for 144"- 153" $160.00
There extensions are top notch quality.
www.oftracing.com
www.oftracing.com
Yamanimal said:I'm no expert, but if you really want a 153 you could probably relocate the
I highly recommend against this.The nytro already has havy steering if you relocate the skid on a nytro it's almost uncontoable on the trail is all over the place.
Yamanimal
pro116 said:Yamanimal said:I'm no expert, but if you really want a 153 you could probably relocate the
Ahhhh I see, good to know. I kinda thought the mtx153 had the same length skid as the xtx but located further back.
