basic700
- Mar 5, 2010
- Norwalk WI
- 2018 Sidewinder STX DX 146
2015 SRViper XTX LE
2009 Nytro XTX
How do you adjust the weight transfer on an xtx to make it wheelie???
radianguy
- Jan 1, 2007
You need to adjust the transfer rods in the rear suspension. Check your manual if you are not sure, set transfer toward max and wheelie!
gregdec1
Do you increase the weight transfer or decrease it?
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
correct me if im wrong but increased transfer will compress the suspension more when you give it gas which will pick your front end up
00-NUKE
basic700 said:How do you adjust the weight transfer on an xtx to make it wheelie???
When you loosten the front limiter straps on your rear suspension, it will allow more weight to transfer to the back when you are on the throttle. This will allow you to pull wheelies. The problem is that it will reduce significantly reduce ski pressure at mid and full throttle when riding, loosing mid to high speed cornering.
