Yamaha apex 144 project
Dirtbikekid1998
Age
26
Maine
2014 Yamaha Viper LTX SE Hurricane 190hp Turbo.
This was what i got torn apart on the first weekend.
skid taken apart and painted, 144 extensions drilled and bolted in place thanks again muffin works these extensions look awesome, new wheels and pioneer 135 wheel mounts, fox mega float added and all put back together. then pressing new extovert drivers on
skid going back in and tunnel extension being riveted on. i have to say with the fox mega float the skid is really easy to be put back in, all you do is let all the air out of the shock and put the front 2 bolts in and just slowly drop the sled down and the two back holes line up almost perfectly!! i cant wait to try it out this winter.
taking out the old mono shock adjuster and adding a aluminum piece.
coolant temp gauge with a half done wiring pic, i have since replaced all the connectors with sealed ones.
mostly put back together.
home made ram air lid, i followed Rockerdan's diy post and after following that it was pretty easy to do.
putting on white Yamaha skid plate. and drilled and bolted on kimpex ice scratchers onto my skis.
then when i had the front end up to put on new carbides my front end bushings were really bad soooo.... back apart again and called Allen Ulmer and got his oilite front end kit, hopefully i wont have to do it ever again.
painted my vents white and then put it back together and added the muffin works tunnel supports.
pcv/ignition module with map switch. and Yamaha heater, man these grips get really hot!!! this is going to be one of my favorite things for this winter no more cold hands!!!
soon to come hopefully. rox blue/white hand guards, rocktoyz hids, trail terminator clutch kit, new skis, and front fox floats
Looks great! Nice job.
what do you guys think on skis, C&A xtxs or slydog 8" powder hounds
