GeorgianBayGuy
- Nov 19, 2010
Everyone. Sorry about posting this in both the General section and my 'home' section, but i think the news is very interesting
From Yamaha Canada.
Everyone;
This was emailed out this morning and explains the situation regarding new parts.
TRIC Ice Scratchers. Last year we introduced these flexible cable scratchers based on a version that has been sold by Yamaha in Europe for a number of years. What appeared to be quite simple on the surface turned out to be rather complex in the application. We made some running changes to reduce the amount of deflection in the cable which yielded satisfactory performance in the intended conditions. We still had deflection issues when the cables were operated at higher speeds or with too much pre-load. Over the summer we investigated multiple improvement ideas with our supplier and in the end, went with a fairly simple upgrade. We have added a ‘damper’ in the form of a hi-impact plastic tube to the cable and changed the crimp on the Babbitt to allow more radius. While we were at it, we standardized the hole size to accept common studs for greater selection and easier maintenance. We will be recommending the cable be taken out of play when not required (simply loosen the bolt and raise them up off the snow) and continue to advise against operation at sustained high speeds. The production has started and we will be shipping out well before Christmas.
The new Tuner, dual keel skis. These babies were tested last year and the design was approved. Production samples were received this fall and had to go through another round of approval which, after some minor delays, appears to have the green light. Production, if it hasn’t already commenced, will very shortly. The Tuner carbides come from another supplier and they are on-track for delivery. The catch in all this is the number of skis per week produced will be under 100 pieces, so it will take a bit of time to fulfill all the orders but we should be well on our way by Christmas.
The Yamaha Dupont super sliders. The impregnation of the Vespel chips into the hyfax material has presented a unique challenge for our supplier. Early samples were not able to meet our satisfaction and some tweaks to the new manufacturing process were required. The latest samples are looking really good and production is ramping up. Our supplier is even planning to add a shift to turn the orders around faster and these should be hitting our dealerships soon as well.
More good news, the Oil-Lite bushing kits for the front ends are arriving, we just need to get the installation instructions confirmed and they’re a go. Another decision was just made to offer a body kit for the FX Nytro that contains bright’ red-armor’ dipped side panels and hood. If you aren’t familiar with this, the plastic water dipping process has been used on our special edition ATV’s and the ‘red-armor’ was the most popular. The pricing looks like it will be quite reasonable and the quantities are limited so if you have banged up your sled or just want the custom look, you might keep an eye out for this one. I’ll post some more details when available.
Finally (and this is arriving this week), we have the tether actuated, roll-over switch which will cut-off the oil tank breather to avoid the loss of oil in the event you part ways with the sled during a bank turn or failed high-mark maneuver., not that that would ever happen to you …
I know this all sounds like a lot of hurry up and wait but it is never as simple as it seems on the surface. Prime time for new product announcements is September; fall trade shows, Hay Days, media events etc. afford the best opportunity to show and tell before the snow flies. We decided to roll the dice and announce our plans while still in the final phases of testing and production approvals. I know some guys are chomping at the bit to receive some of this stuff now that they know its coming but I think it is more important that we get it right. I forget the vintner who used the tag ‘we will serve no wine before it’s time’.
cheers cr
From Yamaha Canada.
Everyone;
cheers cr
Super Sled
- Feb 25, 2009
- Summit X
Thx for the updates CR!!!!!
Muskoka Man
Good one GBG
Hows the Gt running ? How many Ks did you get in on it last year ?
MM
MM
oldguy2
- Jan 16, 2012
- Saskatchewan, Canada
- 2010 RS Venture 2006 Apex ER
- Fort Qu'Appelle
Thanks for the updates. I ordered the ice scratchers today and was told they are back ordered.O well.
