how clean gas tank
TOMBOB
Saranac,Michigan.
2006 APEX ER
. How do you clean the gas tak
2, does it mater if filers is on on side or the other our just on one side
3. Befoe i removed the tank I set fuel meter ay one bar remove the tank drain out 3 gals gas
4 help hint to change the filter use 2’ wood dowel attach it to wire with a taper fit attach a dowel
To hose’ use hook wire to attach t0 filter. Pull dowel and wire back to get to the filter;’
gas tank
looking at oem parts
top filter lays on right side---bottom on left siding on the slide
