Stopped to see if their were any up dates on rtx I was told yam. put some hold down brackets on coils to keep them from vibrating up. Someone got the bright idea to locktite them on rep said these should be taken apart and cleaned carefully while it is warm out or you might not be able to get these off on the trail if need to. when doing the windshield gauge cluster removal instead of unplugging on rear of cluster follow wire harness down and unplug so there is a pig tail from gauges it's supposed to be easier to get back together.Also said diff. # oil filter it's a little shorter mec. said you could use either one.also changed the spark plug tops I think he said to steel to wear better.
welterracer
The coils on the apex's have screws holding them in!
