zeke66
Just wondering what your thoughts are on them? How long you have had them and how dependable they are? Any major engine problems?
I am thinking for next year. Already put a #*$&@ load into the Nytro this year but I am 99% sure I am going some kind of boost next year. Guess I am just looking for input. May as well start gathering info.
I am leaning Supercharger because it is linear and I do mostly all trail riding.
Ratpack
- Oct 11, 2006
- Frewsburg NY
- 2003 RX1
I have had mine for two years and love it. The only thing I have had to do is add more boost. Always want more. We put one on a Nytro, and it wasn't to bad. If you decide that a s/c is what you want you'll never regret it. My motor is stock and has around 3000 miles with boost. No issues. Sorry I jumped around in my response but you get the idea.
zeke66
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
For trail riding, I love it. Fast throttle response. Easy as hell to install and use the stock fuel tank. Easy to remove as well, when/if you decide to sell the sled.
The gems box could use some vamping though. Thinking about going to a pc5 setup for fuel control. The gems controller does work okay though. I get around 10mpg...less if I am hammering it all day.
All in all, great little set up.
sheetwright
- Jul 7, 2008
- Northwoods USA
- 2021 Yamaha SRX
How much boost would you want to start with and how much could you see yourself ever using on your sled? That really starts the questions about how to start, or what you will need
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
Had to edit my post....
the belts and oil are not that bad in costs. Just payed $40 for the crank belt, and $60 for the 16oz oil.
Ratpack
- Oct 11, 2006
- Frewsburg NY
- 2003 RX1
1Crazysledder. I had not heard that you should change the belt like that. I ran mine for two years and only broke it cause I had it to tight.
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
Ratpack said:1Crazysledder. I had not heard that you should change the belt like that. I ran mine for two years and only broke it cause I had it to tight.
I thought someone awhile ago told me that. Can't remember who, Alan, mack, matt, but I have had the same belt for quite awhile also. Only reason I am changing it is because I can see an outline of the drive gogs on the outside. I will use it for a spare if I have to, or keep the new one as a spare and run her until she blows.
zeke66.Why do you want to switch friom your ulmer stage 1 to a superchearger?
Super Sled
- Feb 25, 2009
- Summit X
Hey Pro, I think he means he's running Ulmer Stage 1 clutch kit, not Stage 1 turbo kit.....
zeke66
Super Sled said:Hey Pro, I think he means he's running Ulmer Stage 1 clutch kit, not Stage 1 turbo kit.....
This ^^
Thanks for the input guys. Basically want it to be rideable on trails and still be able to use pump gas. I do not want to have to use any race fuel.
Ratpack
- Oct 11, 2006
- Frewsburg NY
- 2003 RX1
Not only rideable, but 100 times more fun. The fun factor is huge. I run 7 lbs. with 93 pump gas. Two years and nothing but fun. THE Nytro also runs 7 on pump 93.
Agman 57
- Dec 28, 2006
- Fostoria, Ohio
- 2018 Apex XTX LE, 50th Ann.
2018 Sidewinder LTX LE, 50th Ann.
2017 Sidewinder BTX LE
1992 V-Max 4 (Modded)
2002 ZR 120 G-daughter's
Have had the MPI S/C for 2 years now, no trouble, nothing different than the fun factor!!! Loose just a little MPG, but way worth it.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
2005 RX 1 Limited.
Stage 1 MPI 5.5 lbs until this year. No issues , 7000 km.
Sold it to a friend who is a Doo gearhead so he took it to Woody for a 10 lb upgrade. Woody says she looks like new inside.
One heck of a sled.
One heck of a sled.
