Could everyone please post in this one thread, your clutch setup for the 3rd gen clickers in a apex. I have searched around and when you search clickers, you get so many threads that don't have anything to do with actuall setups. It would be good to have a single thread for this.
Turk
Tech Advisor
Are you talking heelclickers?
If so they make 3 different types.
Need way more info!
Need way more info!
sorry turk, 40-10, they are the 3rd version.
Turk
Tech Advisor
Start with white hc spring
5 grams heel & 4 in tip
bone stock secondary
should be very close.
I run the sled tonight with the above setting, I did add 1g more to the tip and ran a softer spring in the rear, everything else as above. sled engaged around 4500 and really didnt grab the belt till 5500, way too light during and after engagement. from about 60-70mph on up pulled very good but still hitting 11,000
clutch has stock 15mm rollers.
Ill have to do this the hard way, on the trail
