- Apr 14, 2003
- Hessel, Michigan
Gentlemen,
My apologies in reference to a post I made last night that was false and untrue. I commented that I had no evidence of secondary spring coil bind and I would like to set the record straight. Two weeks ago, I went riding and hit low 120's several times. Upon arriving home, I took clutches apart and found no evidence of spring coil bind. Apparently, I wasn't going fast enough..........Last weekend I went riding and hit 125-126 half a dozen times and had no belt issues, therefore ASSUMED I had no coil bind based on my findings the week before.
Well today, I finally had a chance to disassemble clutches and inspect.......to my dismay.....blatant evidence of coil bind!!! I feel like a turd !!!
Part of resolving these issues is putting our heads together and reporting facts based on testing, to which I have failed. My sincerest apologies for dropping the ball. MODERATORS, PLEASE DELETE THAT POST SO NOBODY GETS STEERED IN THE WRONG DIRECTION!!!!!
Moving forward, I have since shimmed helix 90 thousands, wound the tension to 70 degrees, and will retest. Nos Pro.......sorry I doubted the facts you stated and I still look forward to hearing any results from the viper secondary.
No worries man....we are good!
Just like jonlafon1 says...you set it straight. Takes a big man to admit that and post about it.
We are all here to help one another. Best site ever!
silverram323
- Mar 24, 2013
- Jodrell St, Cambridge, mn 55008
- beyondsynthetics.net
- 2017 Sidewinder XT-X 141
Why doesn't one of our vendors make a billet helix shim?
Sent from my iPad using Tapatalk Pro
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Well, what's the fix to make the stock clutching work without blowing belts?
Pierre Castonguay
- Aug 25, 2016
- Saguenay, Quebec
- Viper, Apex, Sidewinder
As for roller spot and broken belt go with a 41/37 helix at 3/3, will reduce belt tension and heat! The stock 35 helix on the secondary clutch is not the proper helix! With that set up never broke a belt, and trust me I ride my sled extremely hard!
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Dalton?As for roller spot and broken belt go with a 41/37 helix at 3/3, will reduce belt tension and heat! The stock 35 helix on the secondary clutch is not the proper helix! With that set up never broke a belt, and trust me I ride my sled extremely hard!
Pierre Castonguay
- Aug 25, 2016
- Saguenay, Quebec
GFORCE, in Quebec I know the guy is name is Gille he has the world record for sled top speed!
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
200 mile day yesterday. A lot of grade trails / fast hard pulls. Straight 38 helix works awesome. Little lazy in the middle but weight adjustments will solve that. VERY happy with my clutching with this helix. Better then stock and very trail friendly. Had to drop the middle hole of the heavy hitter weights. I agree with belt heat being LESS WITH MORE HELIX ANGLE. I had less belt dust also!
yamaha06
I have 250km on my sled, haven't blown a belt yet. Just wondering about clutch heat. Did two back to back runs wide open throttle for a decent distance stopped and checked the clutches, I could hold my hands on them for like 15 seconds but they were pretty hot. I read some could hold there hand there as the clutches were just warm. I'm running stock clutching and 8jp belt. I have helix shimmed, is there anything that can be done to make clutches run cooler?
kylechargerrt
- Dec 8, 2013
- Scotland Ontario
- 2017 YAMAHA SIDEWINDER LTX-LE
1998 MACH-Z
1250 miles blew oem belt today.
Sent from my SM-G920W8 using Tapatalk
MooDoo
Fourth belt blow and one primary spring 1700km/1050miles. Oujeah...
3 DN and 1 JP and JP blowing before 60 miles...
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
I'm sure youve checked your offset? Is the shim on the jack shaft behind the clutch ?Fourth belt blow and one primary spring 1700km/1050miles. Oujeah...
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
When did it go? Wot? Did it chew it up or snap it?1250 miles blew oem belt today.
kylechargerrt
- Dec 8, 2013
- Scotland Ontario
1998 MACH-Z
70mph rolling over hills. Matted it. She peeled the top off.
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
That is usually a heat issue. Were your clutches hot.
kylechargerrt
- Dec 8, 2013
- Scotland Ontario
1998 MACH-Z
Barely warm too the touch. I was thinking of changing it as it didn't feel like it was 100%. New belt and it feels good again. Will probably shim the secondary when I bring it home this weekend.That is usually a heat issue. Were your clutches hot.
- 13K
