Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
- 2017 Sidewinder BTX LE
2012 Nytro XTX 1.75
Is anyone not getting flat spots with stock rollers?
Can the roller pins be removed with secondary all assembled on sled? Looks like I need to take helix off to removed spring?
Sorry for dumb question.
Stock rollers 1700 miles no flat spots
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
That's great!.. Curious how tight do you run your belt? Like your belt deflection? Is your belt up really high in secondary? What belt you running? You stock boost? Sorry for all the questions!Stock rollers 1700 miles no flat spots
Thank you!
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
2012 Nytro XTX 1.75
Stock no tune run 1/16in down in secondary shimmed helix and running 6-1 setting, changed my belt out at 1100miles just because but it looked great. I have a BTX LE so I get 50/50 on and off trail and ride hard on trail my clutches run cool no complaints here but could use more finish angle in helix Rpms drop some haven't decided on a clutch kit yetThat's great!.. Curious how tight do you run your belt? Like your belt deflection? Is your belt up really high in secondary? What belt you running? You stock boost? Sorry for all the questions!
Thank you!
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I think the secondary works better when you keep belt deflection down like yourself.. Hence your 1/16 down below sheaves.
Even a smidge more then 1/16 is okay IMO..
Just a theory I have about the rollers and contacting the helix ramps..
IT seems to me 6/1 setting on spring and the belt riding below secondary sheaves is BETTER..
I think some including myself WERE or are trying to get that belt to ride up to high over the sheaves, and I believe this causes the rollers to be even further off helix ramps.. Just my opinion
Thanks for the INFO DieselXTX.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Just trying to decide if i am going to swap them out before loading up the trailer. My belt rides just like diesel describes.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
If the rollers are not flat, don't sweat it.. Can you pull secondary off machine and work on it where your headed?. Its simple working on these secondary's once they are off machine.. If your not comfortable doing it and they are not flat spotted bad > leave themJust trying to decide if i am going to swap them out before loading up the trailer. My belt rides just like diesel describes.
actionjack
- Apr 9, 2005
I service the bearings on my Attak every season so I'm cool taking it off. I've just never cracked a primary secondary chancase or valve cover otherwise I've fixed most other things.
It seems some think the torlon rollers are smoother and maybe that's just because they changed out flattened rollers. I expect to be at 1st service after my next ride opportunity and my dealer does that for free (besides fluids) so I may let them ride.
Pstn head
IMO remove the secondary and change the rollers on the bench, less chance of dropping a bolt or pin in the sled.I service the bearings on my Attak every season so I'm cool taking it off. I've just never cracked a primary secondary chancase or valve cover otherwise I've fixed most other things.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
I'm running 6-1 no shim. Seemed to be working really good but yesterday is chopped a belt clean in half.
Other then the belt 6-1 with cat rollers has been good.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Which belt did you pop?I'm running 6-1 no shim. Seemed to be working really good but yesterday is chopped a belt clean in half.
Clean break is likely primary pulling and pulling and the secondary cant give anymore(bind).
Just so little room between those secondary spring coils. Maybe try shimming ?
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
8jp beltWhich belt did you pop?
I might shim it. But I like the idea of a new helix.
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
2012 Nytro XTX 1.75
I will have a new helix once a proven angle is out but for now 3 washers does the trick and holding 106mph on my BTX is fully shifted out and belt looks great.
8jp belt
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
I got Hauck rollers coming..they are quite abit cheaper then others ive looked into.
Are you just giving Hauck a free plug. If I am not mistaken Thunder Products are $45 so you sure didnt look all that hard.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I did look at every roller I read about here, and they were all 79 to 89 bucks.....Are you just giving Hauck a free plug. If I am not mistaken Thunder Products are $45 so you sure didnt look all that hard.
Just was surprised someone had some much cheaper....My bud had already bought them, did not even know Hauck was still around these days.
Sorry bout the post, I will remove image Tom.
