tedgoesfast
i had 22-39 back to 23-38
Nemesis6
What were you running against the 4tec and why the change.i had 22-39 back to 23-38
tedgoesfast
2005 rx1 team tied secondary air box mod set up well 96 studs
tedgoesfast
what ive learned team tied struggles with top end numbers when geared down and getting close to overdrive i will see what gearing up alittle does
tedgoesfast
but at 100 mph race done at 1000 ft do you catch him
Nemesis6
Probobly 1500 feet but going by hard. So were you runng the lower gearing when you ran the 4tec. If I could get a better take of I could beat him. Should I gear down a little.
tedgoesfast
i hen i got a team tied secondary put apex weights in with rivot out of end.but it takes alot of time to set up .Ulmer makes a good kit and a good price.i think gearing down with stock secondary it still will have good top end try one tooth down.Come out at 10200 let it pull to 10500 at end
tedgoesfast
make sure your getting good weight tranfer so you can leave with him
Nemesis6
Should I put in more studs
tedgoesfast
we always race with a roll on about 10 mph then nod and go makes it more fair then.then sleds plays more then traction
tedgoesfast
does he have ecm reflash turning it close to 9000
Nemesis6
He says Cudney told him to turn it 8700. In a 10mph rollon I still spin
tedgoesfast
what year is your sled
tedgoesfast
how can i get ahold of you
Nemesis6
2005what year is your sled
