dylanjen9
Does anyone know the part number for apex oil drain plug on crank case? I cannot find it on the parts diagram. I’m sure there are aftermarket but I like staying with factory
YAMAHA GENUINE PARTS' 2007 Yamaha
dylanjen9
Where is drain plug? Mines a 11 if it matters
RobX-1
- Coldwater, OH
Do you mean the chain case as I don't believe there is a plug on the crank case:Does anyone know the part number for apex oil drain plug on crank case?
RobX-1
- Coldwater, OH
dylanjen9
Crankcase. The one underneath sled. You have to remove little skid plate to get to it
RobX-1
- Coldwater, OH
So, you just need the oil drain plug that you remove when changing oil? Guess I never referred to the oil pan drain plug as the crank case oil plug.
RobX-1
- Coldwater, OH
#6 (bolt) & #7 (copper washer)
