Are the fixed primary sheaves the same on a 2000 SRX as the 03 RX-1 or are they different angles? Also, whats the best place to buy a grunt tool from?
Turk
Tech Advisor
Shives are the same. Grunt tools are all way overpriced for what you get. Try maxximum.
rxwhopper
i built my own bottom, i took the old stationasry shieve, and drilled out the 3 holes in it, then set it on i thick plate steel, drill threw the plate using the 3 holes, and then i put bolts through the plate, welded another plate on the bottom to put in the vice, bottom is easy, the to you have to get creative around the spyder
black john
grunt tool
i just had plate made with angle iron welded to the bottem so it could be mounted in a vise and used my comet gunt tool.
