mrosenow
- Mar 23, 2008
- Neenah, WI
- www.harrisonstreetmotors.com
I have a late 2003 Mountain. I trail ride it. I broke a spindle a few weeks ago, just below the lower control arm. I replaced it with a spindle I had from a parts sled. hit a RR track about 20MPH tonight and broke the new one. From the looks of things, the mountain control arms are not as sturdy as the regular RX1, nor are they as wide. The upper control arm does not have any support and allows the spindle to flex back, bending the bolts that hold the spindle to the control arm and in my case, allowing the spindle to crack. I would like to replace the control arms with the wider, more ridged regular RX-1 control arms. Main reason is that I want more stability in the corners...and I don't want to bend another spindle. This will mean replacing the tie rods, for the longer ones???? The other question I have is about the shock and spring. Is it the same or do I need a shock from a regular RX1 with the wider front end?
I have two pairs of RX-1 Mountain control arms in good condition if anyone wanted to trade for a wider nonmountain pair.
