gytrapex
- Oct 5, 2014
- 06 yamhah apex gt
I have a 03 rx-1 we autolite plugs in it now when u start it and turn to the left it spit and spatters but it won't move at all you can shut it down and start it and agin and keep the skis straight it runs fine and till you turn to the left then it dose it any one have this prob
Loosen the adjustment in your throttle cable a bit...sounds like tors activating.
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
My 05 warrior did that and it was the tors. Fix it right don't just bypass the tors. Bypassing it can get real interesting
gytrapex
- Oct 5, 2014
- 06 yamhah apex gt
Thank guys Bc it not showing a code now this may be dumb but what dose this tors look like I'm not use to the rx1My 05 warrior did that and it was the tors. Fix it right don't just bypass the tors. Bypassing it can get real interesting
ZapeX2
If you look at your go fast flipper, it is slotted where it pivots. If the throttle is activated without the lever moving then the TORS is activated, not allowing the sled to throttle up. Throttle cable probably just needs to be loosened somewhere, binding and pulling the cable.
btw...
TORS= throttle override system
btw...
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
Did the sled get a riser put on without a longer throttle cable? Might have to be re-routed to get some slack or go to a mountain sled cable.
