03 rx-1 running like #*$&@
gytrapex
06 yamhah apex gt
I have a 03 rx-1 we autolite plugs in it now when u start it and turn to the left it spit and spatters but it won't move at all you can shut it down and start it and agin and keep the skis straight it runs fine and till you turn to the left then it dose it any one have this prob
Autolite plugs? They make a plug to fit this sled? Sounds to me something's grounding out and I'd start somewhere in the handlebars. There also if I remember post about a brown wire up in the bulkhead grounding out. Try searching it.
Sounds like your throttle cable free play needs to be adjusted or cable rerouted .You may be activating your t.o.r.s. system.
How much free play sould u have
check your throttle cable. Its the safety switch. you need to with the engine off, hood up, turn the bars to the left.You may want to remove the handle bar cover too. You must have a 2" riser on there?
