jtuck
- Mar 3, 2005
Ok guys here is my question, Should I be concerned, when I try to start my RX-1 and it turns over 1/2 Turn and then .. Clunk (loud) & locks up.
Here is the deal, I rode it the other night put on about 75 miles hard rough trails and fast roads. Then pulled it in the barn. Two days later (today) I went in the barn to start it , choke- kill switch- turn key rolled over maybe 1/2 turn then I heard the clunk (like metal to metal) and she froze up. I waited a minute and tried to turn over again and it would not do a thing ( turn 1/8 th then stop).
I then rolled the engine back no problems then foward had a hard time. After doing this a couple of times it seamed to free up? Then I tried to start, it turned over and started. Let warm up add a tittle spin around the yard did not seem to be any problems. Going on a trip soon and wanted to know If any one has seen this problem before. 8) Oil level good Thanks for input..
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
Check your battery terminals and all conections, then do a load test on it.
jtuck
- Mar 3, 2005
Battery was plugged into a tender untill last week plus new last Febuary, but I wil check it out..
pull the plugs and see if it spins over.
rxwhopper
you might of had some condensation, i would try to believe that anyway, would let me sleep at night lol
SLEDSTART
I thought I read somewhere thet there is no need for fuel shut off on these, but it sure sounds like you had excess fuel in the motor. Were you over half tank and did you park in on any type of angle? When you started it did you smell un-burned fuel? Exhaust tips wet?
jtuck
- Mar 3, 2005
I have installed fuel shut off's but I did not trailor after I rode and Had parked on flat surface. I have started it a couple times now with no trubles. Wonder If I had a valve stick ? Or some freak bind in the gearing??
SLEDSTART
strange...don't ya hate when you don't really know what something was that you heard?!
Especially when it's that loud!
