03 rx-1Seat re-stuff
kinsound
Southern New Hampshire USA!!!
I have seen some info on updating a 03 rx1 reat .. i have done it with foam from an uphoslstry shop but it did not cut it.... anyone have the correct foam name density and any other info I can give them to get me the correct type foam
Use the same type of foam that is in the seat or more foam that is even more dense. It is the shape of the foam/seat/suspension that is at fault not the foam.
If you are considering keeping the sled for a while??? then I HIGHLY recommend an Apex/Nytro seat.
IMHO:The difference between that and a stuffed seat is incomparable. Plus you get a trunk as a bonus.
kinsound said:
How about a 05 vector seat......??Will that be enough?
It would be better, but still not as good as the Nytro seat.
