03 rx1 backfiring
jrosko said:
Still popping and backfiring after cleanin carbs. Now what ?
its AIR, GAS, and SPARK. Stick a screw driver in the plug wire and ground it to metal, what color is the spark? Must be blue/white, anything else and the coil is bad. Is it getting gas to the carbs? Pull lines off of fuel pump and crank (might use a catch can). Is the air filter installed properly? If it is any of the above simple fix. Most likely it needs the carbs cleaned again, this is very common, many of us have needed to clean the carbs several times.
