'03 RX1 - Fuel overflow line excessive leak & carb quest
jmbones
Northeast PA
'03 RX1 - Not sure if related, but had the airbox off to replace the battery. When I put everything back together and fired it up, there is alot of fuel pouring out the one overflow(?) line. At first I didn't notice where it was coming from so I removed the airbox again and also noticed some fuel coming out of the carbs when running. Is this normal and would the airbox normally collect that and burn it off? Also why would it pour out of one of the overflow tubes?
Thx
Take your carbs off and clean them. Sounds like you have a float stuck. Those carbs need cleaned every year.
