Yes like maim said you will need links from a 12/13 mm sway bar. links from an apex or attack should work. The 03 rx1 comes with a 10mm. You will also need sway bar bushings from the same sled, they are 13mm also. It takes 5, maybe 10 minutes to change. Makes a huge difference in cornering.
