03 RX1 TRANSFER ROD ADJUSTMENT
mxkelly
How should the transfer rods and shocks be set for good weight transfer and bite on takeoff? Thanks :4STroke:
Transfer rods should be set so that you do not wheelie on acceleration, but not so long that you have excessive ski pressure. The rest is a balancing act to get the handling performance you desire. You might try a search. We have been down through this process several times already this season. The info is out there. You just need to do some searching around.
