mikeinchicago
im sure you all been over this 100 times whats the best way? cut the connection on seat or sled or both?
sleddheadd
I would either remove the entire wire assembly from your RX seat and install it on the Apex seat or I would cut the wires on the seat side and not the sled side.
onlyblue
i did the sled side and put in a trailer connector 4 way plug between the sides on a vector i did this with. worked really slick. Easy to unplug for seat removal and nice and tight. (cheap and easy too!)
mikeinchicago
thanks again, I already have seat connected to sled so ill cut the wiring of rx seat that way it will plug in
Sled Dog
onlyblue said:i did the sled side and put in a trailer connector 4 way plug between the sides on a vector i did this with. worked really slick. Easy to unplug for seat removal and nice and tight. (cheap and easy too!)
X2 that is what I did as well and it worked very well.
