derbydriver7
- Nov 21, 2014
- 2004 Yamaha RX1
my 04 rx1 has developed a problem, it has done it 3 times now when it sits say like overnight or for 3-4 hours it acts like it's dead as a door knob at the key...throw a charger on a 10 amp charge for 30 seconds and it takes right off...when it takes off after putting the charger on it spins motor super fast even without the charger on, then after it's been started its fine it won't do it again until it sits...anyone have any advice as to where to look and what? Am going to get a new battery even though it's not turning over sluggish at all but I'm guessing it's few years old thanks for any help
It could be the starter sticking...and the brushes are warn enough it wont turn it over unless there is a pile of current. Does the sled have a pile of miles?
derbydriver7
- Nov 21, 2014
- 2004 Yamaha RX1
1903 miles on the sled...took battery to local napa they tested it and said it's good
This is a tough one.. hate electrical issues. When this happens try jumping the relay by the better with a screw driver...I have seen those get moisture in them.
derbydriver7
- Nov 21, 2014
- 2004 Yamaha RX1
Ya I'm afraid it's wiring also...when I put charger on it's hooked to what I'd call those tender cables that hang out under the air box would that send more juice to a relay or solenoid of some sort? Leaving Saturday morning for first trip north bad timing for it to be giving me fits
Yes are connected to that area.... its worth a try. It acts just like the battery is dead. Turn the key to on, then take a screw driver and see if you can jump that relay.
derbydriver7
- Nov 21, 2014
- 2004 Yamaha RX1
Just got to take it on a 10 minute cruise...probably died 30 times on me...this time charger didn't help when it died, ended up getting it into garage got to messing around ended up on the key switch where key switch plugs into wiring took that apart one of the pins on each connector is green hoping that this is my issue
That could be... so it died as you were driving?
derbydriver7
- Nov 21, 2014
- 2004 Yamaha RX1
Yup last couple days it just wouldn't start, now it acted like some hit the kill switch when riding it
It could be the key... if it was really green and the contacts were extremely corroded.Yup last couple days it just wouldn't start, now it acted like some hit the kill switch when riding it
derbydriver7
- Nov 21, 2014
- 2004 Yamaha RX1
Just one of the contacts had corrosion and it was pretty nasty, both sides, on the key side and the wiring harness side same contact, unsure of wiring diagram but if clip to release the plug was on top and you would unplug the connection it would be top right contact looking into plug on wiring harness, top left on the key switch, I believe that's the correct one, i cleaned contacts inside the connections as good as I could plugged together started fine say there and wiggled plug wires for atleast 5 minutes never hiccuped once, checked rest of wiring harness all around that area all looked perfect no rubs anywere, hope that was my problem. Frustrating to finally get snow and then it don't run!
Indy
Sounds like your loosing ground, try running an extra ground from the sylenoid to the chassis (this fixed mine).
derbydriver7
- Nov 21, 2014
- 2004 Yamaha RX1
Yup my key switch one of the terminals inside the plug to where plugs into wiring harness had corrosion works great now!
