rageit
10000 Kms, it runs fine at low rpm, then when I crack the throttle as it gets up to speed there is a strange sound like a four stroke atv, sort of low rumble. The sled bogs and chugs along. Any guesses what might be wrong?
theCATman
- Feb 19, 2007
- WI
- Yamaha
Throwing any codes with or without check engine light?10000 Kms, it runs fine at low rpm, then when I crack the throttle as it gets up to speed there is a strange sound like a four stroke atv, sort of low rumble. The sled bogs and chugs along. Any guesses what might be wrong?
If not, likely a clutch issue. Broken spring, worn pucks on the helix, sticking weights from worn bushings.
Sent from my SM-G930R4 using Tapatalk
rageit
No codes, what makes you think it's clutching. Primary or secondary?
theCATman
- Feb 19, 2007
- WI
- Yamaha
If the engine is getting pulled down under load, it could be clutching.
Will it rev up clean on a stand?
Could be filthy carbs too? Fouled plugs??
I guess I'd start with the basics like clean carbs & new plugs.
But, at that mileage, clutch components can't be ruled out. Again, broken spring either clutch. Worn bushings in primary causing weights to stick. Worn buttons on the secondary helix causing bind.
rageit
Yes it revs good on the jack. I had it out last week with no issues. Today we had several inches of really wet snow and I was running drifts, could this be why the clutches were having problems. I limped it home, should have run down the road, that would help with not much resistance.
theCATman
- Feb 19, 2007
- WI
- Yamaha
Could be.
Were you busting big drifts? If so, you mighta ingested alot. Airbox full of snow, ice, & water. Might wanna check that too if so.
