05 rage not iddling back
snow tundra
Joliet Il
My rage will idle back to 1400 rpm but it takes about 30 seconds to do so. I had the carbs cleaned and balanced at very good yamaha dealer. The sled runs great good gas mileage 17 to 19 good top end after trail riding I let up on the throttle it goes down 2100 rpm then 30 seconds later down to 1400. The sled has 9000 miles on it. Carbs were green inside. I think to much sea foam. I have a 06 venture with 14000 miles on it idles perfect.
Just set the idle screw down a bit more it will start idling down quicker then its fine.
If the carb's are sync properly and it's still hanging at higher RPMS decrease the idle slightly and it should drop back much quicker.
