Sledhead774
I just purchased a 2005 Rage used and was wondering if Yamaha will perform any recall work that may not have been done prior to me owning it at no cost...like warranty work. Are there any posts on here that cover all the recalls of a particular machine? Please help. I'm new to 4 strokes (recently converted from the dark side) and don't want to mess this machine up. Thanks.
- Jun 28, 2004
- Clinton, Wi.
Contact a local dealer with your VIN#. They will be able to tell you what if anything has been done under warranty, or if any updates or recall's are needed.
Sledhead774
Thanks for the help.
pistons
For TSB info go to snowmobileworld.com
ragefarmer
what is tsb and where is it?
rupprider
tsb= technical service bulliten
pistons
What puter where you using??? 10:24am!!rupprider said:tsb= technical service bulliten
pistons
Technical service bulletins can be found at snowmobileworld.com Get logged in. Click on Forums at the top next to Home. Scroll down to Recalls/Service Bulletins. There ya go.
ragefarmer
found it thanks, i only found two for the 05 rage, the TORS which i think my dealer did, and primary clutch sliders and o-ring, i don't recall that being done though, i may have to give him a call. its supposed to stop the rattle.
frano
What was the TORs update?
cat hunter
wut r the updates tHAT i can get for my 05 vector from dealer as recalls
fedorov5549
- Feb 10, 2007
Thought there was a secondary shaft bulletin and a cdi bulletin. Get in touch with a dealer.
