vt_rx-1
When for the first ride on the new RX-1..WOW! Tons of power, great motor and extremely smooth. It was a little tipping in the corners and too much ski lift, will work on that. But when it was warm the only way I could get it to start was to give it some gas. Is this normal and if not what do you think is wrong. Thanks guys!
rx1mtn
I have always had to give mine a little gas, have over 1500 miles, and still do.
What's it idling at? I'd get through a tank of gas first, adjust the idle to around 12-1300. My 05 starts like a swiss watch.
goldbergrx1
i have to give it gas .....only have 150 miles on it but everytime so far had to do it
vt_rx-1
It is idling around 1400 but it is beginning to sound like this is normal.
welterracer
Its pretty normal for them to need you to give it a little throttle while starting..
After i sincronized my carbs i didnt have to hit the throttle at all... starts alot better!
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
The gas heats up in the carbs because of the coolant that runs to them. Which is the reason many of us have installed a carb coolant shutoff valve.
impalapower
Give it a little gas at startup. Idle is fine, don't know what it is though.
vt_rx-1
Thanks for all the replies..
MightyW..... what are you using for a shut off and when are you closing it?
