if i hold it steady at 60 and then get on the gas, the sled won't climb. i don't lose rpm's, it doesn't sputter, but it won't climb. if i start low at about 20 or so, it'll climb to 90+. any ideas???
I wonder if you have a deep groove in the clutch face making the belt hang up... I know that the vector clutches develope a groove from normal wear.. Also the clutch may need to be taken apart and everything checked for lube. MM.
