CharlieAZ
- Dec 20, 2016
- Nutrioso, AZ
- 2015 Yamaha SRViper LTX DX and 2005 Yamaha Vector RS ER makeover 2017/2018
- Vail,az
- AOL
- Palmercmp0466@aol.com
Anyone know what the spec from the top of the secondary should be for proper belt deflection , I just put on a New Clutch
and a New Belt and want to make sure I am good to go. Thanks Charlie
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
It's in your owner's manual. It shows V-belt position is to be from 1.5 mm above edge of secondary sheave to 0.5 mm below that sheave, and how to make adjustments by removing or adding spacers to the three adjusting bolts on the backside of the clutch.
CharlieAZ
- Dec 20, 2016
- Nutrioso, AZ
- Vail,az
- AOL
Thank you for your reply. I think I am good then as I am dead smack even with top of secondary Sheave.It's in your owner's manual. It shows V-belt position is to be from 1.5 mm above edge of secondary sheave to 0.5 mm below that sheave, and how to make adjustments by removing or adding spacers to the three adjusting bolts on the backside of the clutch.
CharlieAZ
- Dec 20, 2016
- Nutrioso, AZ
- Vail,az
- AOL
Another question, I took off the belt to take another look at the secondary , is it normal for the secondary to have a small amount of play on the shaft toward the engine and back its small... But I am new at working on clutches and want to make this is OK, as everything seems to have to be very precise .It's in your owner's manual. It shows V-belt position is to be from 1.5 mm above edge of secondary sheave to 0.5 mm below that sheave, and how to make adjustments by removing or adding spacers to the three adjusting bolts on the backside of the clutch.
rotational or the shaft moves front to back? rotational is normal.
CharlieAZ
- Dec 20, 2016
- Nutrioso, AZ
- Vail,az
- AOL
Clutch is moving on the shaft , horizontally ,little play in it maybe a 1/4 inchrotational or the shaft moves front to back? rotational is normal.
normal as it is supposed to be self centering on the jackshaft spline.
CharlieAZ
- Dec 20, 2016
- Nutrioso, AZ
- Vail,az
- AOL
Thank you!normal as it is supposed to be self centering on the jackshaft spline.
thrasher
- Nov 22, 2006
- 06 Vector RS ER
Yup. self-aligning.
