06 Apex w/ Simons CPR Front Mount Turbo Pics
Simons CPR
TY Advertiser
Here are some of the first pics to be shown of the Apex Turbo, we are just about done with it, we are in process of fabricating the plenium tank right now and should have some dyno numbers for you in around 2 weeks. jeff
it looks impossible to do, until you pull one apart, theres plenty of room. jeff
Next winter won't come soon enough! Got anything figured with the fuel injection yet? couple extra injectors in the intercooler or what?
200 hp at 7.5 lbs boost level is where i think it will be on a fully heat soaked engine. and we will use whatever fuel support system is necessary. jeff
jeff - the stock hood seals around the stock air box kind of making the air box part of the hood. how are you going to address this issue? Will you use the stock hood or have an after market hood? ( a Diamond-S hood would be neat and would help in cooling)
many ways to hand it, we will probably have a molded hood scoop to make more of a ram air for the intercoller, or you could do as little as cut that part from your airbox and epoxy it to the hood for a completely stock look. jeff
