06 RTX rear skid clunking noise
Mr WFO
Lake Simcoe ONT CND
Anyone have a clunking noise in rear skid when going slow over sharp bumps ? I can recreate the noise by setting the dolly wheels under the skid at the very back of the track and lifting up and down on the rear bumper. The suspention will clunk when you come to the end of travel.It will do the same noise even if I increase the preload or adjust the clicker.I believe its the transfer rod making the noise when it comes to the end of its travel. but its in the mid position, the sled is brand new 300 miles and the rear shock works nice .Is there supposed to be spring tention in the transfer rod??It seems to have a long stroke!
"I believe its the transfer rod making the noise when it comes to the end of its travel."
That's normal on the mono shock
Yea its sagging fairley quick when you lift it to the top of the shock stroke and let go but a firm clicker adjustment will slow the saging down again its worse when the track is on the dolly at the rear
