KubotaOne
My understanding is that the "clunking" noise coming from the Attak's rear suspension when going over stutter bumps is "normal", specially noticable at slow speeds. It's the transfer rod and limiter strap doing its job.
My question is, can I reduce it by adjusting my suspension or straps? With the lack of snow here in Ontario, most trails are passable, but un-groomed, so my speeds have to be slow, and the annoying clunking sensation is getting to me.
Any suggestions?
Any suggestions?
LazyBastard
You can try to dampen the clunk by replacing the nylon spacers in the upper and lower control rod gaps with rubber bumpers.
Slush Monster
LazyBastard said:You can try to dampen the clunk by replacing the nylon spacers in the upper and lower control rod gaps with rubber bumpers.
Are you thinking of the pro action. He has the monoshock. This is not the same. What abought setting the control rod adjustment for more transfer. I never noticed any clunking in my Attak but also had the control set to max.
redrx1rkt
I hear that clunking on my RTX. Glad to know it's normal.
yamaslob
Same problem here that mono shock doesnt like studder bumps at low speeds at all tons or weird noices glad its all normal.
KubotaOne
So no reducing the "clunk" affect?
TT670
Id bet you could put an o ring on the transfer rod to dampen those clunks. Im going out to the shop to take a look.
KubotaOne
love going to the shop, mines 100km away during the week, you lucky bastard, thanks for checking!
LazyBastard
Slush Monster said:LazyBastard said:You can try to dampen the clunk by replacing the nylon spacers in the upper and lower control rod gaps with rubber bumpers.
It doesnt matter what skid. ANY skid, even a non-yam skid. Make rubber in the control rod.
Rash
Today, I noticed mine for the second time... at slow speeds on little bumps... And it didn't do it before... I tightned the track it was at 2 inchs, no change... so look elswere... and tell me what you find...
RASH
RASH
canadianhunter
Had the same low speed clunking on my 06 Rage, so increased the RA dampening- didn't help. Then soften [reduced] the RA dampening and now it rarely ever clunks.
RTK
Go FASTER
- 146K
