06 rtx vs 07 rtx
Grahamsville N.Y
What would be better?? I know the looks go to the 06 but is the 07 any better then the 06 or should I just go with the 07 or save the money and get the 06? If i get the 07 we are going to be putting a down payment on it this week. :die
I guess it comes down to whether you want the Mono or the Pro Active CK. Someone around here mentioned some gearing changes, but I think that might be unconfirmed. You can't go wrong with either one!
The 07 rtx is unreal in the moguls and a lot better riding than the 06 but on a smooth trail it will be a toss up.The pro active skid you can prload the skid before moguls and jumps which it makes it a blast to drive and with the lower gearing.If your an aggressive rider I woulkd go with the 07 but if you mostly just a trail cruiser and like to crank it up once in a while I would go with the 06 and gear it down.
Ok, If we get it we are going to put a bender stage 2 turbo, would that take care of 1125 zr?? zr8 with a motor mod. Would the stage 2 be trail safe? So if i ride hard go with the 07 ok, is there a speed diff or a weight diff??
if your main plan is to turbo it, you should go with an attack for the extra traction. I read that on the turbo section. gordy
You will want a longer skid with a turbo for hookup so either year would work. The only advantage you would have with an 07 is the 3 year warranty but kiss that goodbye once you install a turbo. So with that being said and with the 06 Killer looks I'd go 06 ;)!
2002 viper said:
But i want the fox floats!!! :Rockon:
So add them to the Attak!! ;)! I mean, after all, you're talking spending $11,000 on a sled, $5,000 on a turbo, and then you can't/won't spend $600 more for the shocks? What's wrong with this picture?
:Rockon:
:Rockon:
Ohh, I didnt know that you can add them to that sled, Deff going to look in to that. :Rockon:
the rtx would be better in the rough stuff.You caould getr a 136" kit from hartman and have the best of both world's.
Only reason I was told to go with the attack because I am planning on gettin a stage 2 turbo. :Rockon:
