yamahinn03
- Dec 28, 2004
- oshkosh, wi
- 18 Sidewinder (Wifes)
12 Nytro XTX (mine)
09Apex GT (?)
02 Viper (grass dragger)
Anyone have the numbers for it, my seal is not sealing spittn grease out.
Thanx
Bearing behind the clutch.
Thanx
RobX-1
- Coldwater, OH
If you're referring to the jackshaft bearing which is behind the secondary clutch, then #18 is what you need.
https://shop.portyamaha.com/fiche_s...=Snowmobiles&make=Yamaha&year=2006&fveh=33506
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
Did you repack that bearing? I do mine every year and it usually throws a little bit back out for the first ride or two.
True, if too much grease is put into bearings, they tend to shove some back out.Did you repack that bearing? I do mine every year and it usually throws a little bit back out for the first ride or two.
yamahinn03
- Dec 28, 2004
- oshkosh, wi
12 Nytro XTX (mine)
09Apex GT (?)
Dont remember If I did last year or not?? But definatley did the year before. Wifes sled so only gets 500-700 mi a year!
Will run it an check mid season an see what it does.
