06 Vector limiter strap and suspension set up
smurf
wisconsin
Could someone please tell me what the factory setting is on the front limiter strap? I'm 170 lbs and mostly trail ride with occassionaly running it hard. How do any of you like to have your suspensions set up?
Thanks for the help,
Smurf
First thing I'd do is see what hole it is currently in? Mine was not in the middle to start. Depends on what you need to achieve? I needed a little more front bite in the corners, so I'm one tighter than center position.
Not sure if its "factory" but mine was in the last hole (making the strap the longest) when I bought it new. I tried tightening it one hole but didn't like the results (to much ski pressure) so I put it back. I weigh 178 lbs without gear.
my 06 gt came with the limiter strap in the second to last hole...i thought the sled had to much ski pressure so i put it in the last hole...i run 6" stud boy shaper bars and i also shimmed my ski's...this set up has worked great for me with little to no darting...
on my vector I never touch the limiter strap if you want to change ski pressure just adjust the transfer rod thats what its there for made a huge difference on mine
