hixtract
- Nov 16, 2008
Does anyone make an aftermarket oil tank, or a solution to the tanks leaking. I have replaced 2 in the last 3 years,any help would be great
RX1Jim
Where do they leak from? Do they crack or is a leak at a fitting??
Fergie
- New Jersey-Ride Old Forge N.Y.
They crack about 1" up from the bottom front
hixtract
- Nov 16, 2008
The tank cracked on right side about 2" up from the bottom near the seam Has anyone tried to repair the tank or just by new from yamaha
Fergie
we tried jb weld & it did not hold up for us, we then had it welded at a welding shop & so far so good
x2thez
- Mar 29, 2005
- Buffalo, NY
- 2014 Yamaha Viper LTX
2009 Yamaha Vector LTX
1987 Yamaha Bravo
I have put JB on mine and it doesnt seem to be holding. What kind of welder do they need to use? Also How did you remove the JB weld after you got it on there?
RX1Jim
I would scrape as much of the JB weld off the tanks as possible, then have it lightly grit blasted to leave a nice, clean surface. You'll need someone who is a very good TIG welder to weld it. It will take a very good welder since the tank metal is thin and easy to burn holes in it. I believe the tank is steel so the crack could also be brazed/silver soldered. If you can't find someone in your area to weld it for you, send me a PM and I can fix it for you.
Handy
- May 12, 2005
- Anola Manitoba
- 1983 Bravo, 1988 XLV, 1991 Pazer II, 2005 Vector, 2006 Apex Super Charged, 2017 Viper STX DX 137, 2018 SR Venture DX
The tank is aluminum. Do not sand blast the crack if you plan on having it tig welded, the sand contaminates the weld area and will always leak. Just have the tank cleaned at an automatic transmission shop, thier hot tank solution is the best for aluminum parts. Then take the tank and have it welded. The other option would be to upgrade to a tank from a 2008 Vector which is a totally different shape.
bsevigny
- Mar 25, 2006
- Minnesota
- 2016 Vector XTX 1.75 LE with Elka Shocks
2013 Vector LTX
2016 Polaris Assault with 159 track and 35" front
2009 Polaris RMK 700
What I am Trying
I also cracked my tank on the bottom-right bolt flange.
I bought a new tank and put fiberglass mess from Bondo on the front and back and around the flange. It will be interesting to see if this sticks, holds and helps.
Bgs
Bgs
