How thick are the grommets you got? Wondering if I should put a couple rubber washers from home depot between the posts and the tank mounts... Just as a precaution?
I just used some that I already had. I'm also into street bikes and also have a drag bike and a track bike so i've got small parts like that and nuts and bolts around. I did drill out the mounting holes slightly so that the bolts would fit snugly through the rubber grommets. I added loctite to them as well since the rubber didn't allow it to be torqued to the proper value.
