moses3m
yamaha has problems with there 06 apexes exhausts the gaskets wear out at about 5000 miles
i own an 07 and i would like to know did yamaha make any changes to adress this problem any help?
ApexRtxGuy
You will still need to check yours around that 4500 to 5000 mile mark.
moses3m
who is this i am mark mortimer from deforest
Len Todd
moses3m said:who is this i am mark mortimer from deforest
You may want to try PMing him. Lots of the guys are tight lipped when it comes to real names. Don't know why. But they are.
Myself and 4 other '07 Apex riders check ours and found them to be OK. We all have over 3000 miles and 1 had 4600. I'd wait until you start noticing a leak.
ahicks
4200 miles, 1 good, 2 bad, 1 gone completely. The only symptom was a very slight ticking on idle.
Another Phase
It seems fairly consistant. I had the same results when I pulled mine apart as far as good, bad and completely gone. I have noticed that most of those who have posted have had similar findings. It would have been interesting to keep track of the locations of the good donuts vs the completely gone donuts I think there may be a pattern.
Len Todd
Mine are still holding tight at 8K+ miles. Knock on wood.
moses3m
thanks for the info. i'll keep my eyes and ears open i would like to keep hearing more info on this keep up the great work
ReX
Len Todd said:Mine are still holding tight at 8K+ miles. Knock on wood.
I believe the 04's use steel headers and they don't suffer anywhere near as much with the header problem compared to an Apex.
I have heard of some guys installing 04 RX-1 headers on their Apex and they claim they don't break. I believe they had to slightly modify the headers to make them work though.
darv
- Aug 9, 2005
- 08 Apex 40th LTX
talked to yamaha rep today showed him mine he said he has nerver seen or heard of this problem but said they have no problems with this i was the first one he has seen whata good Bulls***er
Fergie
- New Jersey-Ride Old Forge N.Y.
does anyone know if the exhaust donuts are the same on an 05 RX1 & an 07 attak.
Len Todd
Fergie
Thank You.
Roadrunner
darv said:talked to yamaha rep today showed him mine he said he has nerver seen or heard of this problem but said they have no problems with this i was the first one he has seen whata good Bulls***er
What a
