shakyjake
Hey im looking for a good used 07 Attak in blue. I know alot about Yamaha sleds but at the time the 06 Apex/Attak line came out I was still riding my 02 viper, and Srx, so my 06/7 model year personal knowledge isnt there. Sold the Viper last year and the SRX is up for sale now and Im getting into an Attak or Apex LTX asap and I would like to know if there were any inherent diffences between the 06 and 07 Attak models. I know usually there is first year model quirks and trying to find out if the 07's had any updates/upgrades or if buying an 06 is nothing to worry about. Not sure....any insight is very appreciated.
AttakSnow2
- Aug 17, 2005
- Merrill, WI and White Pine, MI
- Yamaha Viper
Besides a few color changes, the only update they did to the 07 over the 06 was update the handlebars to a 1 piece design.
Most of the used sleds you find out there, might already have updated handlebars on them. There was a heating issue with the end of the bars, so many people switched them out.
timebomb
grease fittings on the skid
shakyjake
Thanks for the info, hopefully I can find a good buy on one soon, I really dont want to wait until the snow flies, that way it will give me some time to go through the thing before winter. What is a safe stud length on those models in case I find one without studs?
sherlock29
1.375"...some run 1.45" but its starting to get a bit tall... i have 168 in both @ 1.375"... but can still get them to break loose at 50+ mph..
AttakSnow2
- Aug 17, 2005
- Yamaha Viper
I run 1.40" in mine. They'll still hit the heat sheild from time to time. I have 144 down the center.
i run 96 down the middle with singles and doubled 1.375 snd it hooks with no slip. it takes off straight and fast.
CaptCaper
- Jan 1, 2007
- Northern N.H.
I'm running what woodys recommened. 162 down the middle with 1.325's. 2 seasons and no problems.
The newer the sled is the more improvements they did.
I get confused between the Apex and Attack in 06-07 but gear ratio changes,skid changes were done besides the handle bars. Also the chain case cover was changed. 06 would leak out by seals. If you get a good deal on 06 you can put some money to bring it up.
My 07 has been good to me except Y pipes were going at 6k but they were warrantied. $240 for parts if not.
shakyjake
CaptCaper....did you have to do an add on aftermarket rear cooler on your 07 Attak or did it come standard in 07?
CaptCaper
- Jan 1, 2007
- Northern N.H.
I added one aftermarket. I got one for around $100 from Port Yamaha. If you run studs you'll have to add 1 1/2 in of protection directly over the cooler.
I'd buy another 07 if I could. Every year they made them better but every year they are more and more money to buy.
