Srx700pilot98
- Feb 17, 2019
- Hudson wi
- 98 SRX 700
00 SRX 700
01 SRX 700
07 Apex GT
I had a low fuel light on, parked on a slope. Cranked with no start..temp -14. I figured the slope created no fuel supply. Added fuel and while cranking got a red light. Now turn the key, red light, amber light, no crank. Fuel pump comes on. I found codes 11,22,36,84 stored under #61. I cleared codes. Still red and amber lights, no crank, fuel pump powers up. Any help is appreciated. Thanks. I think all from just having low fuel parked on a slope. I’m wondering if I cranked to long and maybe blew a fuse? I know my battery seemed low, I did put a booster on it to turn over after the first attempt to start as it seemed to turn over too slowly, then I put booster on. I already ordered a new battery.
Usually a no start but ahve a running furl pump issue is the starter or starter relay. With the amount of codes you are getting I would check the fuses both at the fuse block and the ones at the starter relay. Check the ground for the ECM in the front of the sled. Could also be a pesky ground block.
Srx700pilot98
- Feb 17, 2019
- Hudson wi
- 98 SRX 700
00 SRX 700
01 SRX 700
07 Apex GT
Is the starter relay one of the fuses in or near the block? I’ll check all the fuses by the block when I put the battery in. Other than the fuses in and right next to the fuse block I’m not aware of any other fuses. Thanks a lot for the response. I appreciate it.Usually a no start but ahve a running furl pump issue is the starter or starter relay. With the amount of codes you are getting I would check the fuses both at the fuse block and the ones at the starter relay. Check the ground for the ECM in the front of the sled. Could also be a pesky ground block.
There is a fuse box, 2 actually located just below the reverse lever. A larger one and a slim long one grouped together.
2 fuses with the starter relay. One fuse is a spare.
