brad
I bought an 04 warrior with an 07 apex attack rear suspension installed in it, I don't know much about these, so I need some help. My question is ,when I push down on the back end it goes down with no resistance for about 4-5", and stays there, then if you lift it back up again no resistance. Is this normal? or are my shocks bad? When you do push down past the 4-5" then you can tell there is actually some suspension.anyone shed some light for me. Thanks.
LJ 452
Take the front and rear off of the dolly's, problem solved. If that's not the case, check the transfer rod, first make sure it's there, then check it's setting.
