07 Attak drive bearings
kenbar
North-Eastern Canada
Is there an easy way to grease the drive bearings on the clutch side and are they easy to access. I thought I read somewhere that they do not have grease fittings.
You dont have to remove the bearing. Use a needle grease gun and carefully push through the seal. Only use one/two pumps as too much grease will cause the bearing to over heat and fail.
