07 Attak...set up
mr rxl
Manitoba,Canada
I have 1000kms on my 07Attak ER. I finally have the handling right. Machine is all stock.
I first adjusted the transfer with the rod to maximum. That gave me the transfer I wanted , but way too much inside ski lift. I backed it off too 2/3rds and it helped, but still had a bit of ski lift. I took 2 turns out of the front springs, and that gave me the perfect amount of ski pressure.
The transfer and handling are perfect .
The track racheting is gone. Proper tension is a lot more important that Polaris' I've owned.
Raced an 05 Mach last night. In 1/4 mile runs, I would jump out 3 lenghts off the start and stay that way to the end. He only had a 1 inch track, so that may be the difference. :yam:
dont your skis want to come off the ground with that mutch transfer?...i know what you mean about the track tension thats what stopped my racheting,alot different than my poo's
