STILLCRP
- Dec 11, 2006
- DECATUR,IL.
- 07 Attak
Bought 07 Attak new last year. Put 900 miles on it. I weigh 300 lbs.
I have not touched any settings on the sled.I did buy a BB spring and a rear heat exc. from Port last year but have not put them on.I like to run kind of aggreesive.I have tryed to search on my question but no luck.
My sled cornered terrible with the stock ski's called Scott Bergstrom he sold me a set of triple carbides shimmed and put ski savers on per his instructions.Going back up to the U.P. 1ST WEEK IN FEB. I would like to set my sled for my weight and style and get top performance.
THANKS GARY
THANKS GARY
vmaxcrazy
I'm 280 and ride an 06 attak. My set up:
Rear susp: BB spring and recalabrate shock, adj cam for correct (about 3-4 in) sag. Raise limiter strap one hole. Transfer at one notch toward max.
Ski spring: Raise frt of sled off ground, loosen spring and then tighten one turn. Spring should be loose with no free slop.
I have 6.9 pilots also, but skock ski's can be made to work if riding on groomed trails. If you are going to do any off trail riding a wider set of ski's is a must to keep frt of sled from just plowing.
This works for me. I get quite a bit of inside ski lift, but a 13 mm sway bar may fix that. Good luck
