hubdawg
Riding my 07 gt today and stopped for lunch and when I went to start it it fired up then quit. The engine doesn't crank at all and the self diagnosis warning light came on flashing as well as the warning light exclamation point and the blue high beam indicator flashed. Ended up loading it on the trailer and calling it a day. 300 miles on it . Any Ideas?
Amo
I've got money on the wiring harness...assuming you've not gotten the 07 updates done... Have a dealer run your VIN to see if you got the harness/ball joint updates. The starter isn't covered but if you do your own oil changes (good way to save $80), always check the starter bolts...
Good luck!
Good luck!
