07 pHAZER fx?
kviper
Oakfield WI
2012 MCX Turbo Apex
I have an 07 Phazer FX and a couple question's. It has about 500mi, With 96 1" stud's. Coming out of the hole hard the stud's are hitting the rear of the tunnel (big wheelie), Do i need tunnel protector's or shorten limiter strap or what? It is also running 11,700 to 12,000 RPM WOT shift RPM in 4, 5 degree temps, It was pulling 11,600 to 11,700 in 20 degree temp's. Is any one needing to add weight to get rev's down? kviper
with my phazer i used old track sliders for tunnel procetors you could try shortening the limiter strap but then your wheelies arnt as big and fun!!. you should have tunnel protectors on yor phazer anyway cause somtimes your picks will hit the top of the tunnel when landing jumps!.
but sorry cant help with the rpm ive never really had much to do with cluches befor.
Depends on your weight,traction and suspension setup.Let your limiter strap out.It will come up.
Wooly is right belt wear is huge effect on rpms.Ulmers kit works great but it cant account for belt wear.
I put a new belt on and the driven is wound at i think 35 (c-1). Still running 11,800+. I will have to either add bigger rivet's if available or go to a softer primary spring. I pulled limiter up one hole and stud's don't hit tunnel any more, Still big wheelie. kviper
lol my phazer comes right up and i weigh 200+ with my gear on just stand on the back of the boards and pin her she will stand right up on her tail.
I'm 150 lbs. and I just can't get it to stand at all...if there is a moogle or something I can hit it then pin it to have the skis like 3-4 inches off the ground but I want it to wheelie like my rev....it the bumper everytime
i cant get mine up but im only 110lb... itll get lite on the front end but thats about it unless im doubleing or tripling some of my friends then it just pops up with about quarter throttle
