I have read that the 07 RTX has 23 top gear and I have read it has a 22 top depending on if you have reverse or not. I do have reverse, so once and for all what is my stock top gear? Is the 07RTX clutching the same as the standard Apex and/or the Attack? I was wondering for 800 foot runs should I change the gearing and just add a clutch kit or change gearing?
To be honest, the motor has so much pull I don't think I would miss any low end on the trails even if I did gear up.
